relay question
Old May 7, 2015 | 08:44 PM
happyhapka's Avatar
Car: 1986 Trans AM WS6
Engine: 383 Vortec TPI, PUTS SMILES ON FACE
Transmission: PATC LVL 3 Raptor Transmission
Axle/Gears: 3.27 POSI 9 BOLT
relay question
ok so I have a 1986 305 TPI now ive been trying to solve the big code 33 36.. I bought all new relays, maf power maf burn off and fuel pump relay..
now the fuel pump relay has 5 wires but the relay I got only has 4 pins part number is ar225 from napa and there all next too eachother like this (_1111)
next is the only 4 wire I have is for the burn off and it looks like this (1_111)
but the burn off relay I got was from orielys and it has 5 pins.. ?????? and so earlier I wasswitching them around I put my maf on my maf burn off relay cause it has 5 connectors and my fuel pump is being ran off of my maf power relay cause it has 5 and my burn off to the new fuel pump relay cause it has 4 but only 3 are connected to pins on this due to the gap in the plug that I shared earlier... should I repin the pigtail to (_1111) to match or should I keep it at (1_111).
the result.. I had cleared all my engine codes tell later and it was my maf burn off that came back.. I think its cuase it wasn't connected to all 4 pins..
what am I missing why is this sooo complicated.
Old May 8, 2015 | 08:20 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: relay question
Looks like you'll want all of them to have five pins. http://austinthirdgen.org/mkportal/m...ine_wiring.gif It's been a long time since I went looking at these relays so double check the diagram to your wiring.
RazorN8
Jan 7, 2022 11:44 AM
Caspar
Jun 19, 2016 11:19 PM
Bert87
Aug 23, 2015 03:50 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
