Hot Start Problem
Old May 25, 2015 | 03:20 PM
bnewton530's Avatar
Car: 1989 Iroc Z/28
Engine: 5.7
Axle/Gears: 2.77
Hot Start Problem
Hey guys, I am having this strange problem with my car lately. It just won't restart when hot. Then, when i unplug an injector, it starts. The car has spark, fuel pressure at the rails and great injector pulse until it is hot. I put a new ICM and pickup coil on there. It recieved new ECM about two years ago. I also then completely rebuilt the top end. Still happening. It is factory stock besides an aftermarket coil pack. Any insight would be great. I miss driving my car.
Thanks, Brandon
Old May 26, 2015 | 08:46 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Re: Hot Start Problem
It doesn't run rich does it? that would make it hard to start.
Old May 26, 2015 | 10:40 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Hot soak...Injectors leak down after you drive the car and try to start it back up again. Floods the cylinders.
For a test, hold accelerator to the floor after a heat soak and crank it. Chances are, it'll start.
Time for new injectors maybe.
Old May 26, 2015 | 12:39 PM
bnewton530's Avatar
Car: 1989 Iroc Z/28
Engine: 5.7
Axle/Gears: 2.77
Thanks for the replies. The car did the same thing this morning cold. I already have tried flooring it while cranking and nothing happens. It'll start on starter fluid or with one injector disconnected.
92camaroJoe
Jul 29, 2023 07:57 PM
theshackle
Mar 5, 2017 06:37 PM
92camaroJoe
Aug 13, 2015 06:07 AM
