fuel pressure drop
Old Jun 6, 2015 | 12:36 PM
92crimsonRS's Avatar
Car: 89 trans am GTA
Engine: 355
fuel pressure drop
89 tpi
new pump - walboro 255
new adjustable regulator - southbay-new diaphram
i also have bosch III injectors that are a few years old.
my issue is a rapid pressure loss after the pump stops. like 45psi to 0 in less than 10 secs.
i just replaced the pump thinking it was a pump issue. plus i was getting low flow to the rail and had to fix the filler neck.
had a very erractic gauge needle now its somewhat steady.
so my question is...do injectors clog and leak easily?? i had them out and in a ziploc bag for about 7 months while i rebuilt the engine and trans.
Old Jun 6, 2015 | 06:00 PM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
Re: fuel pressure drop
The injectors can leak down, but you'd probably have a smokey start. You need to test fire them out of the car hooked up to the rail over a bucket. They should stop immediately. However, the more likely culprit is the fuel regulator diaphragm. You can verify which end of the system is leaking down by pinching off the fuel supply hoses. As for the gauge. The oil filled ones are garbage. I drained mine. I would under read every time the car warmed up.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
