89 pontiac ta starts and stalls wont idle
Car: 89 trans am
Engine: 5.0
Transmission: 5 speed
Axle/Gears: stock
I have a 89 ta 5.0 5 speed. I been having problems with it idling and running ruff. some times it will start up and run with no prob but if I shut it off and start it back up it wont idle unless I give it gas. but then it runs ruff and spits and backfires.it has all new injectors, mass airflow sensor, coil, plugs and wires and fuel pump I also checked the tps and that checked out good too.im stumped I need some help plz
Car: 89 trans am
Engine: 5.0
Axle/Gears: stock
Re: 89 pontiac ta starts and stalls wont idle
O ok i will check them out. I also herd that the knock sensors will also cause the same thing. What do you think?
backtothe80s
Sep 5, 2015 12:39 AM
