What happens if you switch two injector connectors?
Old Dec 18, 2001 | 04:28 AM
90Iroc's Avatar
Car: 1990 Iroc/Z
Engine: LB9 305 TPI
Transmission: Borg Warner 5 speed
I've got a missing problem in my car, and I'm beginning to wonder if after my rebuild that I may have gotten #6 and #8 injector harnesses turned around on each other. After the rebuild I couldn't easily read my scribble on the harness. I guess the only way to tell is to switch them again and see if it goes away. The problem is intermittent though. It really acts up at 1500 RPM and again at 3000 RPM. Those two RPM's seem to be the worst. The car is a 1990 Iroc with 305 TPI and 5 speed. The engine will miss in all the gears, so until tomorrow morning.....
Old Dec 18, 2001 | 05:50 AM
Dano 00TA's Avatar
Car: 00 Trans Am/89 IROC
Engine: LS1/L98
Transmission: 4L60/700R4
With the TPI motor it doesn't matter as long as you don't have the 1357 wires mixed with the 2468 wires. Each side injects at the same time.
eightsixseven
Dec 16, 2024 01:50 PM
89GTAOz
May 16, 2020 09:31 AM
Dialed_In
Aug 20, 2015 01:45 PM
Bryan F
Aug 18, 2015 02:28 PM
