wanting to stall
Old Jun 19, 2015 | 05:45 PM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
wanting to stall
wants to stall when leaving a red light or stop sign. new fuel pump ,filter,ignition module and iac. i go to take off from stop sign and its like i have nothing for a second or two then just takes off and runs fine till i stop again.
Old Jun 19, 2015 | 09:05 PM
Fred SS's Avatar
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
Re: wanting to stall
Is it stock of modified? What mods, if any? Have you checked the TPS volts? Should be .54 +/- .08 volts. I've heard .60 - .61 yields better throttle response.
Old Jun 23, 2015 | 06:47 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
i found the problem. one of the wires to the iac came loose in the connector somehow.
Old Jun 23, 2015 | 10:52 AM
Fred SS's Avatar
Transmission: 2004r
Great that you found your problem. As these cars continue to get older, wiring problems will eventually creep in.
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
Bryan F
Aug 18, 2015 02:28 PM
Jake_92RS
Aug 17, 2015 09:42 AM
92camaroJoe
Aug 13, 2015 06:07 AM
