What size injectors for this setup?
Old Dec 18, 2001 | 12:58 PM
Steve91Z28 L98's Avatar
Car: 1991 Camaro Z28
My new motor will be going in after Christmas and I'm trying to figure out what injectors to use. I will have a ZZ4 shortblock with Fast Burn heads and LT4 Hot cam. I will also be going with a modified LT4 intake manifold. All of this will be controlled with an Ed Wright custom prom but I need to know what size injectors will I need. I am thinking that 24 lbs injectors would be too small considering that's what stock LT1's use. I also read that LT4's used 26 lb and so do LS1's so that might be about what I need. Would 30 lb be too big? I'm thinking I'll be making around 400 hp at the crank. Let me know what you think.
Stephen
Old Dec 18, 2001 | 03:31 PM
David 91RS/Z28's Avatar
24's...
The 24lb injectors will be all you need. That's all I'm running now and have plenty of room to work with. Motor is making about 400hp/480tq. Good luck!
Old Dec 18, 2001 | 03:45 PM
91-ZZ4-Z28's Avatar
I run 24# SVO injectors with no problem
Old Dec 18, 2001 | 03:49 PM
91-ZZ4-Z28's Avatar
Also the SVO injectors are rated a little different and are about the same as the GM 26#
toronto formula
Nov 10, 2015 06:17 AM
69 Six Pack
Oct 5, 2015 07:51 PM
gta90
Sep 15, 2015 04:00 PM
bamaboy0323
Sep 3, 2015 06:07 AM
knight72
Aug 10, 2015 09:32 PM
