Relocating battery to trunk???
Old Dec 13, 2001 | 09:32 PM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
I'm thinking about getting the SLP CAI with dual inlets. I was wondering how you guys relocated your battery. Any tips or suggestions? I was thinking about this box: http://store.summitracing.com/partde...083&part=23454 I'd have to get some cables/wire to run though. A friend said that "You also will want to use 1-gauge welding-cable for your positive wire, the usual cheapo 4-gauge wire isn't enough to start the car reliably when it's that long." is this true? And if I'm getting "welding-cable" would I have to put ends on the cable that hook to my battery, or do they come with some sort of ends? And I run the wire through a drain hole in the back of the car and under to floor pan, right? If you can, any suggestions on where to mount the battery would help, pictures would be great too if you can. You don't experience any kinds of problems relocating the battery that far away? I'm mainly concerned with 1)finding a place for the battery and 2)how to run the wire. Any help would be great guys, thanks.
Old Dec 14, 2001 | 12:11 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by Hg:
A friend said that "You also will want to use 1-gauge welding-cable for your positive wire, the usual cheapo 4-gauge wire isn't enough to start the car reliably when it's that long." is this true? And if I'm getting "welding-cable" would I have to put ends on the cable that hook to my battery, or do they come with some sort of ends? And I run the wire through a drain hole in the back of the car and under to floor pan, right? If you can, any suggestions on where to mount the battery would help, pictures would be great too if you can. You don't experience any kinds of problems relocating the battery that far away? I'm mainly concerned with 1)finding a place for the battery and 2)how to run the wire. Any help would be great guys, thanks.</font>
First off remember in an accident you can get over 5Gs of force, so you want it mounted solidly.
Yes, you'll want 0 or 00 cable if your going with a mega motor and not having any starter problems. While I go for overkill to make sure things are right, I run a ground right by the battery to the sheetmetal, and run a lead to one of the bell housing bolts. If you go with a Ford Solenoid, and do things right, this is really fool proof.
Old Dec 18, 2001 | 04:00 PM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
I used summits kit. It was only like 30 dollars and it included everything except a remote start solenoid. Those only cost like 5 bucks.
Falcon50
Aug 22, 2020 03:26 PM
3rd gen money
Oct 11, 2019 09:57 PM
RS Reaper
Oct 17, 2018 07:52 PM
meeklay812
Oct 1, 2015 03:46 PM
drumstixer
Sep 29, 2015 03:02 PM
