Vortec Heads
Old Aug 28, 2015 | 08:16 AM
earlpote's Avatar
Vortec Heads
Hello all,
I recently got a blown head gasket on my 89 GTA and am looking for clarification on what vortec heads will work on my 350. I have the edelbrock vortec intake manifold with runners already so I figure ill swap heads while im down there anyway. will everything bolt right back up like stock or are modifications needed? thanks
Old Aug 28, 2015 | 09:10 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Re: Vortec Heads
Yes but if you are using TPI exhaust manifolds those will not bolt up you will need to get headers. I found that out with my last swap. Thing is if you are wanting to keep smog legal they have headers with air tubes now that will accomodate you and the added power is well worth the price swapping over to headers.
Old Aug 28, 2015 | 09:28 AM
earlpote's Avatar
Re: Vortec Heads
I have edelbrock headers installed right now, not sure if those will work ill have to find out which ones they are
Old Aug 28, 2015 | 09:29 AM
earlpote's Avatar
Re: Vortec Heads
also can you recommend a good, cheaper head? im ok with iron heads, don't want to spend the cahs on aluminum.
Old Aug 28, 2015 | 10:08 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Re: Vortec Heads
For 650-700 a set Vortecs bout as cheap and best bang for buck. The 083 TPI heads aren't bad. Dart makes a good head not too pricey.. If youre not wanting a huge HP gain man Vortecs are the way to go and believe me they will definitely make great power over any stock GM head out of the box. They are great heads.
Old Aug 28, 2015 | 10:42 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Vortec Heads
SOME Vortec heads bolt up just fine to TPI manifolds, just have to pay attention and make sure the set you get has the 7th bolt hole. Similar to the water pump bypass port in a Vortec block. Some Vortec blocks have the bypass hole cast/machined into them. I have a couple that a machined for mechanical fuel pumps as well.
84z96L31vortec
Aug 20, 2017 12:16 AM
Tinbender59
Mar 17, 2017 10:50 AM
92projectcamaro
Jan 18, 2016 08:00 AM
z28guy134
Sep 1, 2015 11:50 PM
L98GTA87
Aug 11, 2015 06:55 PM
