Fuel regulator retaining spring?.
Car: 1993 Caprice wagon "Shammoo"
Engine: tpi'd 406, with P4 ebl EBL 730 ECM
Transmission: custom "4L65" swap.
Axle/Gears: 3.42:1 with posi
The adjusting screw on my fuel regulator keeps wiggling loose, dropping my fuel pressure, and making the car un-startable and or un-driveable with Afr leaned out to 19-20.
Obviously there is a big spring inside the regulator. I'm wondering if there was suppose to be a small external spring to keep tension on the bolt? Or maybe a lock nut to keep it from wiggling out?
Transmission: T-5, TH350, T-5
Re: Fuel regulator retaining spring?.
The one's I've worked with have a locknut on the screw.
9192camaro
16
Feb 3, 2019 12:21 AM
ambainb
Apr 25, 2016 09:21 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
