350 tpi . Cam and Nitrous.
Old Nov 6, 2015 | 03:49 AM
Iroc_Lopez28's Avatar
Car: 1988 IrocZ
I'm planning on doing a 350 tpi swap where my 305 tpi used to lay. I wanted to know what would be a good cam to use if I was planning on using nitrous? Everything else will stay stock except for the cam (obviously) rockers and springs. Any suggestions?
Old Nov 7, 2015 | 01:07 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: 350 tpi . Cam and Nitrous.
The power adders board may get better responses than tpi. I've never ran nitrous but I would think if you're keeping the tpi manifold that you'd want to use a cam that works with the tpi first and worry about the nitrous aspect second.
Old Nov 7, 2015 | 04:00 PM
Car: 1988 IrocZ
Ok thanks I'll try that. I did forget to mention I will be running a SuperRam intake.
Zylinder
Oct 14, 2016 01:08 PM
89Pontiac
Apr 5, 2016 06:04 PM
Fishy4Life
Oct 29, 2015 07:25 AM
321GO!
Oct 27, 2015 08:16 PM
509 camaro fan
Oct 11, 2015 01:52 AM
