Throttle body help
Old Nov 19, 2015 | 12:30 PM
THIRDGEN87's Avatar
Car: 87 FIREBIRD / 89 TRANS AM GTA
Engine: Ls1 / 350 L98 TPI
Transmission: 4l60e / 700R4
Axle/Gears: 3.73 / 3.27
Throttle body help
Hey guys, I'm looking at a 52mm polished BBK throttle body for my 89 GTA the one I see I can get it for a dea however it says it's for a 85-88. My buddy is a mechanic and says it will work but I have to use my throttle position sensor ect. He states they will bolt right on. Is this true?
Old Nov 19, 2015 | 01:26 PM
heat seeker's Avatar
Car: 89 Formula
Engine: 383 SBC/HSR
Re: Throttle body help
Just a heads up..... I have a AS&M 58mm (out of my 89 Formula) for sale with the correct linkage for your car. Half the price for a new one. Is it the car in your sig pushing 500 hp?
See thread link....
https://www.thirdgen.org/forums/engi...mm-1050-a.html
Old Nov 19, 2015 | 01:54 PM
GraveYardShift's Avatar
Car: Mostly 92 firebird
Engine: L98 350 tpi
Transmission: 5 speed
I have a throttle body of an 86 on my 92 350tpi. 58mm bbk i believe. Not sure if it bolted up but the po said thats what it was off of.
Old Nov 20, 2015 | 08:25 AM
THIRDGEN87's Avatar
I'm looking to put it on a 89 gta with mild mods cam Cai headers and Flowmasters. I think a 58mm might be too much for it
Old Nov 20, 2015 | 09:36 AM
Car: 89 Formula
Engine: 383 SBC/HSR
Gotcha.....no prob.
Old Nov 22, 2015 | 11:22 PM
Fred SS's Avatar
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
You need to look at the throttle cable hook up. That BBK throttle body has the straight pull throttle cable hook up. I have that throttle body (non-polished version) on my car. If your car has the wrap around style throttle cable hook up then that polished BBK will not work without you changing out the throttle cable.
Old Nov 23, 2015 | 07:29 AM
THIRDGEN87's Avatar
That's what I've been reading. However the guy is including the throttle cable as well. My concern is that the airfoil holes match up. I know I'll have to port the premium as well. Thank you.
BobKnake
Car Audio
Jan 16, 2016 06:14 PM
heat seeker
Nov 23, 2015 01:22 PM
L98GTA87
Nov 20, 2015 02:03 PM
lt1z350
Brakes
Nov 18, 2015 06:32 PM
Steve86TA
Exterior Parts for Sale
Nov 16, 2015 02:05 PM
