TPI 730 ECM pinning question
Old Dec 8, 2015 | 02:18 PM
R3500's Avatar
Please delete...answered
Old Dec 8, 2015 | 06:13 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: TPI 730 ECM pinning question
Yes, pin C6 is the optical/digital 2K PPM VSS input. Also need to change a flag in the calibration to tell the ECM to use that pin.
The '90-'92 TPI cars used the 4K PPM magnetic input.
RBob.
Old Dec 8, 2015 | 06:24 PM
R3500's Avatar
Old Dec 9, 2015 | 08:00 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Originally Posted by R3500
OK Thanks...just to be sure...Pin C6 will work?
Yes, just need to also change the calibration flag to use that input.
Could not locate anything to indicate it is the "optical/digital 2K PPM VSS input". All my reference material just say "C6 not used".
Don't know what reference material you are looking at, but as I posted the '90 - '92 TPI cars don't use the optical/digital input. So it wouldn't be documented.
However, in your first post you state, "My reference material says to pin that DRAC output into the 730 ecm at pin BC-6 (32 pin black connector)." So there you go, pin C6 is the optical/digital VSS input to the ECM..
RBob.
Old Dec 9, 2015 | 08:38 AM
R3500's Avatar
Old Dec 10, 2015 | 10:07 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
RBob
Not trying to be an Ahole..Let me try again..I don't have a circuit board schematic for the 730 so I can't trace BC-6...I just want to know how it (BC-6) ties into the 730 board.
Already have the flag changed and memcal flashed.
This post of yours doesn't make any sense to me. You first asked if pin C6 was the proper input for a 2K PPM optical VSS sensor. As I posted, it is the correct pin. Now for some reason you won't believe me unless I post schematics of the '7730 ECM, why?
RBob.
OldMan89
Sep 7, 2023 01:44 AM
blue86iroc
Dec 7, 2015 07:30 AM
L98GTA87
Nov 24, 2015 06:19 PM
knightinblackar
Nov 21, 2015 12:28 PM
igende
Nov 9, 2015 08:48 AM
