Porting base and found inj
Old Dec 30, 2015 | 03:16 PM
87hellbird's Avatar
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
I am porting my full intake and while doing so I got injectors for free that are out of a 5.4 1998 f150 that are supposed to be 19# inj so I was wondering if these work as a stock replacement on my 305 I know that Ford's fuel pressure is 40 which isn't a problem. But supposedly these inj are good to 304hp from factory. I have the plugs for them and everything, I just knew everyone used the 5.0 inj so I was seeing if this matched up as well. Also if anyone knew when porting the base on the tpi what not to port much as I have read the floor or roof is pretty thin.
Old Dec 30, 2015 | 03:18 PM
87hellbird's Avatar
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
Re: Porting base and found inj
Last edited by 87hellbird; Dec 31, 2015 at 10:55 AM. Reason: Wrote in wrong thread
Old Dec 31, 2015 | 11:19 AM
87hellbird's Avatar
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
I know someone has to know a thing or 2 on this.
Old Jan 16, 2016 | 05:54 PM
Mike 92LX's Avatar
No with your fuel pressure they will be 22lbers
Find some Bosch 3s part number 0280155771 and run double orings to get the height the same-they are 19lbers with your fuel pressure. If you can't find them message me I have them for $25 shipped.
Old Jan 17, 2016 | 12:37 AM
87hellbird's Avatar
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
Actually its actually the fuel inj company that sets # per hour not ford and it's universal 43.5 psi from the inj company. ford just runs 19# inj at 36-40 psi which is actually less. I got the inj in and the entire car running. the inj weere short height wise but putting an o ring at the bottom got them to work
Old Jan 17, 2016 | 11:46 AM
87hellbird's Avatar
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
Re: Porting base and found inj]
Old Jan 18, 2016 | 07:14 PM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Couldnt tell you on the injectors but theres plenty of material on a stocker for porting. Dont go nuts on the floor but theres ample material to pick up cfm quite a bit.
five7kid
May 24, 2016 01:31 PM
fletcher0780
Jan 21, 2016 06:57 PM
truckerz
Dec 12, 2015 07:49 PM
Jeep09
Dec 7, 2015 10:34 AM
