AIR system only to one side?
Car: Camaro Iroc-Z -89
Transmission: Automatic
Hi!
I discovered that the air being pumped to the exhaust sytem/headers only goes to the left hand header. The connection on the right hand header is blinded. Is this correct?
BR,
Per
BR,
Per
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Re: AIR system only to one side?
No, it should feed both sides. There's a crossover pipe that goes behind the engine.
Hi! Okay, funny because mine ONLY feed the left side through the pipe behind the engine (AIR pump and valves being on the right side). Consequenses? Uneven temperature?
Thanks for helping!
Thanks for helping!
As far as I recall that Air pump system is primarily for emission testing. it only runs for a short time after start up to help clean up emissions etc. So if it isn't functioning so long as the holes in the manifold are capped off so air can't get in I don't think it not being connected will hurt anything.
peterc005
Brakes
Dec 27, 2015 09:17 PM
