1989 Camaro Irocz 350 won't restart after warm
I have a 1989 iron with the 5.7. When I first start it, it fires right up and runs as long as I'd like but with a high idle. After I shut it off and try to restart it, it won't fire again. Cranks over strong and is getting fuel. I have replaced the cap, rotor, plugs, wires, coil, ignition module. I know there's more. If the time is out on the car could it cause this? Thanks!
Car: 1992 Z28
Engine: 383
Re: 1989 Camaro Irocz 350 won't restart after warm
Check your fuel pressure after shut down to see if your injections are leaking and flooding your engine. Also ohm your injectors cold then hot.
Dave Schotz
Dec 26, 2015 09:15 AM
