How to install Vortec dizzy in SBC OBD2?
Old Jan 17, 2016 | 01:10 AM
evilstuie's Avatar
Car: 1985 Pontiac TransAM
Engine: 400SBC 24x conversion
Transmission: T700r Stage2 Shiftkitted
Axle/Gears: 2.77 9 Bolt
Hi Guys,
Can someone help me out here with the correct procedure to install the vortec distributor into the block for the 0411PCM swap?
This is actually my first engine build, but I do remember reading something about cylinder 1 at top dead center and then turning the distributor x degrees to seat it.
I'm assuming the only way to find TDC is to take the valve cover off and watch for the valve to open/close?
Old Jan 23, 2016 | 08:08 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Re: How to install Vortec dizzy in SBC OBD2?
Yeah like that, but you have to be TDC on the compression stroke. Did you remove the old distributor already? You can also remove the spark plug and ball a piece of paper up into the spark plug hole and turn the motor, when the compression stroke starts it will force the paper out.
I'm not familiar with the vortec distributors do they still use a rotor inside or does it just fire spark based on the cam sensor? If it still uses a rotor then it should be pointing at 5 O'clock once the distributor is installed.
85c1500
Jan 1, 2016 11:30 PM
db057
Dec 24, 2015 07:11 PM
Sean Brereton
Dec 24, 2015 11:24 AM
jorgeblancojr
Dec 23, 2015 10:05 PM
rh76camaro
Exterior Parts for Sale
Dec 22, 2015 07:14 AM
