SVO injectors - get them at Ford Motorsports or where?
Old Dec 22, 2001 | 11:02 AM
BlazinOR's Avatar
Still debating over the Accel injectors or the SVO's............when I read the price for the SVO's was $155 for a set of 8 kinda got my attention. Where did you guys get your SVO's?
Old Dec 22, 2001 | 11:52 AM
irocbsa's Avatar
I don't use thr Ford pieces but I know you can get them at any FMS dealer.
bsa
Old Dec 22, 2001 | 01:00 PM
kevinc's Avatar
Car: 1982 Z28
You can get them from Summit (www.summitracing.com) but I personally like the new Accel injectors better.
The newer Ford injectors look like they changed to ball type, they have a plate w/ holes machined in it at the base. The pintle-type are my personal preference...they tolerate higher operating pressures better according to the press.
The other nice thing about Accels, other than being pintle-type, is that they're flow rated at 3 bar same as GM does. Ford does their flow rating at ~39psi which means their 24lb/hr is really more like 26lb/hr at 43+ psi which TPI operates at. Accel says theirs are flow-matched to within 1% as delivered...pretty nice.
Accels are also available at Summit, prices are within ~$20 of the Fords.
Old Dec 22, 2001 | 06:40 PM
FstBrd6point3's Avatar
don't buy you injectors through the FMS catalog, that is all I can say, they want like 350 from the catalog, when U can get them very cheap at other places.
Old Dec 22, 2001 | 06:53 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
I typically buy used from eBay and then have them cleaned/flowmatched.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Veaceonee
Sep 29, 2016 08:15 PM
92-Formula
Dec 12, 2015 10:34 PM
webeeZ28
Sep 14, 2015 12:00 PM
