Dies when put into gear
Old Jan 30, 2016 | 06:28 PM
Logan Bryant's Avatar
Car: 1991 RS
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
My maf was messed up, so I unplugged it, and left it unplugged. I didn't have a problem before, but now with my new maf, it will die when ever I put it into gear.
Old Jan 31, 2016 | 12:05 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: Dies when put into gear
if you are one of the unfortunate ones, that bought a re man cardone or spectra . thats all they do .junk in a box . you can buy a NEW one . and .really . thats our only choice
Old Jan 31, 2016 | 12:11 PM
Car: 1991 RS
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
I bought a new walker maf from jegs.
Old Jan 31, 2016 | 01:09 PM
Westech's Avatar
Car: 1991 Camaro RS
Axle/Gears: 7.6" 3.73 yukon locker
TCC switch stuck on? its like leaving the clutch engaged and just shifting from natural in to first. It will stall the engine.
Quick test is to jack up the rear and get the tires off the ground and start the car and shift in to drive.
Old Feb 1, 2016 | 05:11 PM
Car: 1991 RS
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
I ended up unplugging the maf and I could put it into gear. Also the car had the maf plugged in and it got to operating temperature, it ran fine.
Old Feb 1, 2016 | 10:55 PM
Car: 86 IROC
Engine: 5.0 TPI
did you ever get your car to run correctly ?
Old Feb 1, 2016 | 11:02 PM
Car: 1991 RS
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
If the maf was unplugged It ran and I could put it into gear, but if it was plugged in it would run, but just would die once it went into gear.
1701-Z
May 31, 2016 09:32 PM
antman89iroc
Feb 2, 2016 02:18 PM
lethaldomestics
Jan 29, 2016 03:06 PM
ken3983
Jan 28, 2016 08:05 AM
BOTTLEDZ28
Jan 27, 2016 03:51 PM
