What goes here?
Old Feb 27, 2016 | 08:07 PM
ken3983's Avatar
Car: 1989 Firebird Formula 350
Axle/Gears: 9 Bolt Borg Warner 3.27 gears
What goes here?
This is the back of a reman 350 engine for my Firebird Formula. There is a threaded hole near where the distributor goes in. Now, the old engine had a plug in that small hole. You could take it out with an open end wrench. However my friends 88 GTA has something there, but I cant tell what it is. I don't think its an oil sending unit on his car. Mine is on the bottom near the oil filter. Whatever is near his distributor has an electrical plug going into it whatever it is. Any thoughts?
Old Feb 27, 2016 | 09:39 PM
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
Re: What goes here?
That's an oil galley. Plug it or you'll have an oil fountain when you prime it.
Old Feb 29, 2016 | 04:03 PM
Fred SS's Avatar
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
Re: What goes here?
Depending on the motor, there would be a oil pressure switch in that hole in the picture. The switch is normally open and closes when it sees oil pressure.
Old Feb 29, 2016 | 04:08 PM
Twin_Turbo's Avatar
Re: What goes here?
being an 89 350 tpi that's plugged as the oil, pressure switch and sender for the gauges are 1 unit, 3 wire type above the oil filter. Your friend has a divorced setup, a can type oil pressure switch there with a single wire and a pressure sender for the gauge above the oil filter.
This is the unit:
Old Mar 1, 2016 | 11:14 AM
KCG's Avatar
KCG
Car: 89 IROC
Re: What goes here?
Am I safe to assume a 89 305/TPI car would be the same?
I have an 86 engine going in and been looking for that connector near the top of the intake, but this would explain why it may not be there.
Old Mar 1, 2016 | 01:16 PM
Lurbie's Avatar
Car: 89 Camaro
Re: What goes here?
Yes, my 89 TPI has the sensor near the oil filter and a small, square head plug threaded into the galley hole behind the intake.
Old Mar 3, 2016 | 05:04 PM
KCG's Avatar
KCG
Car: 89 IROC
Re: What goes here?
ok, Thanks
Old Mar 3, 2016 | 05:33 PM
ken3983's Avatar
Re: What goes here?
This the engine so far.... although he had to swap the valve covers as they were on backwards.
HP52TA
Oct 26, 2020 09:12 PM
BOTTLEDZ28
Jun 27, 2016 09:50 PM
zracTA
Exterior Parts Wanted
Jan 31, 2016 09:18 PM
hart67nova
Jan 31, 2016 07:57 AM
mpoit957
Jan 30, 2016 12:26 AM
