Hard to Start and Backfiring through exhaust
Old Mar 31, 2016 | 10:48 AM
TheJoeY88's Avatar
Ok, here is what i have and what ive done. I have a 1992 Trans am 5.0 TPI, 319,000 original miles, daily driver, stock except for recently changed out injectors to Bosch III's 19#.
Was driving great, then the original GM ICM died. I changed it out for a cheap autozone one to be able to move the car. When i changed that, it would backfire and pop through the exhaust really violently when i revved high and let off.
The new ICM died within the week so i replaced the whole distributor and ICM (got a good deal on a brand new GM RamJet distributor). Replaced it the right way with making sure the rotor was facing the correct way when i installed the new one.
Now that ive replaced the distributor it takes a while to start, cranks for a while and usually wont start until i turn the key for a second time.
I dont think both issues are related since it was backfiring before it was hard to start, but im not sure
I dont know if it is fuel pump related, i will say the pump does whine sometimes when its hot out and ive been driving on the high way for a while.
The car is my daily driver and i drive it about 35 miles a day back and forth to work. Still drives great in normal driving and on the highway but i have noticed a small loss in power.
Old Mar 31, 2016 | 11:31 AM
stephenscamaro's Avatar
Car: 1988 Camaro
Engine: 2.8 to 383
Re: Hard to Start and Backfiring through exhaust
Sounds like the timing may be off. Did you put a timing light on it to verify?
Old saying I use a lot:
Trust, but verify. Verify, verify, and then verify, then you can trust it.
Old Mar 31, 2016 | 01:08 PM
TheJoeY88's Avatar
Yeah I made sure it's right at 6 degrees. I even tried 8 and 0 to see any difference but I didn't notice any.
Old Apr 1, 2016 | 11:26 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Did you have the 'set timing' connector disconnected when you set timing? (sorry, had to ask.)
Old Apr 1, 2016 | 03:08 PM
TheJoeY88's Avatar
Yup, made sure of that
It starts just fine when it hasn't been sitting for too long
irocz43
Feb 24, 2016 05:41 PM
Carystone92
Feb 22, 2016 05:47 AM
Goepfed3054
Feb 21, 2016 10:37 AM
camaroz1979
Feb 17, 2016 10:50 PM
327_TPI_77_Maro
Feb 11, 2016 10:48 AM
