90 GTA Fuel pump fuse location
Engine: TPI 327 SBC Turbo MS2
Transmission: 200-4R CKP Stage 2
I lost my fuel pressure and the fuel pump is not cycling when I cycle the key. Can anyone tell me where the fuel pump fuse is located?
edit : forgot to mention it was originally a 305 TPI car (I think), but it has the factory looking harness and it has a 355 witha Super Ram on it now with a set of TPIS heads which from what I can tell were made for an L98.
Re: 90 GTA Fuel pump fuse location
Found it - next to the radiator on the driver side. I believe some one moved due to the previously installed super charger.
It should be there,
Here, right next to the MSD box
yeah 10 lbs of sh$%#$ in a 5 lbs bag
Even better I have a grinder and a welder
Next - where are both fan fuses? One is in the under dash fuse panel (I think) and the other is ?????
Fan fuse is a fusible link in the orange wire
chevyguy1999
Apr 13, 2016 07:36 AM
