surging issue...
Old Apr 2, 2016 | 02:07 PM
Mrjason24's Avatar
surging issue...
I have a 92 RS injected 305. It has a slight surge to it. Not at idle and not while just sitting in gear. It has a slight hesitation when you first press on the gas. Then while going down the road if you only lightly touch the accelerator it kinda surges. If you lay into it it's fine. Lacks power though. Like it's not getting the fuel. Other then that the motor runs great. Doesn't burn oil doesn't skip or stutter. Any help would be greatly appreciated. Thanks for your time.
Old Apr 2, 2016 | 05:33 PM
no new tires's Avatar
Car: 88 IROC-Z
Engine: GEN 4 LY6 (going forged 408)
Transmission: 60E (going RPM LEVEL 6 4L80E)
Axle/Gears: 7.5" 3.42 (staying...)
Re: surging issue...
The MAF is probably bad.
Old Apr 2, 2016 | 06:10 PM
gw082008's Avatar
Car: 92 Firebird Convertible
Engine: 383 - First Fuel Injection TPI
Axle/Gears: 3:23
1992 models do not have MAF Sensors - they use Map Sensors. Is this TBI or TPI fuel injection? Any modifications to the engine? More info would be helpful. Perhaps you should check your fuel pressure. There is lots of help available from this site so good luck.
Old Apr 2, 2016 | 06:23 PM
Mrjason24's Avatar
TBI...no mods. Was thinking that also. Going to change the fuel filter tomorrow. Don't want to put much into the motor itself. I plan on pulling it out this winter and putting in another motor I'm building.
Old Apr 8, 2016 | 01:38 AM
m16a2r's Avatar
Car: 1988 Pontiac GTA
Transmission: 700r?
well i had the same issue with my 1988 350 tpi, end up being spark plug on cylinder 8, it was partially disconnected and firing at random.
Michael Harding
Jan 12, 2019 11:11 PM
tognabologna87
Mar 24, 2016 04:41 AM
bbernardo94
Mar 13, 2016 09:07 PM
Scorched1984
Mar 13, 2016 10:10 AM
L0tuS
Mar 8, 2016 02:32 PM
