for those who are wanting to drill a distributer hole for the lt1 intake...
Old Dec 24, 2001 | 08:30 AM
zboss86's Avatar
I was looking for a drill bit that size and none was to be found. I found that a 1 and 3/8 metal cutting hole saw will do the trick. Cost me $6 at Napa. But I think they was also wanting to get rid of it. If any body would like I could get the part number.
For the distributer spacing I used to 1 and 1/4 inside diameter washers from napa. They're marked 1 and 1/4 but they're actually 1and3/8. Put two of them together and you'll get your 1/4 inch height. Alittle Jb weld and she's perfect.
This hole doesn't have to be perfect as you'd might expect. There's an 1/8th inch clearance between shaft of the distributer and the actual old tpi intake.
You could actuall drill out the hole too big and then Jb weld the washer where you'd like b/c that's what the distributer will sit on.
Not that anybody cares but,
I just thought I'd save ya alittle time and money.
Looking to get ole 406 going the 1st.
happy holidays!
Old Dec 24, 2001 | 09:06 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Great find!
Thanks for helping people make this cheap mod even cheaper. That's what the LT1 intake is all about.
Old Dec 24, 2001 | 10:33 AM
CORKVETTE1's Avatar
ARE YOU SOME HOW ADAPTING THE LT1 INTAKE TO A REGULAR ENGINE SETUP IF YOU ARE I AM INTERESTED
Old Dec 24, 2001 | 01:13 PM
Ski89Z28's Avatar
Checkout John's Tech Article here:
http://www.sethirdgen.org/LT1.htm
Then do a search here cause some of the guys have found out some newer things and parts to get as above.
Old Dec 26, 2001 | 09:31 AM
RCR's Avatar
RCR
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
I ended up going to a tool rental place in town. I got the 1/2" tap, drill bit for the tap, and a 1 3/8" bit for $60 (all new pieces). I can return them at any time and get 1/2 my money back.
Jeremys87
Jul 14, 2022 09:08 PM
midge54
Dec 27, 2019 04:14 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Thirim
Aug 9, 2015 06:19 PM
rsrmoore
Aug 7, 2015 08:44 PM
