Idle goes up when ALDL is connected ; Camaro 305 TPI
Old May 15, 2016 | 04:28 AM
Zylinder's Avatar
Hello
Camaro 1989 305 TPI
I need some help on WINALDL.
When the engine has warmed idle speed is about 750U/min.
When i plug in the ALDL cable (from Moates) the idle jumps to 1050U/min and stays there. Unplugging the cable brings the idle back to 750U/min.
Why ???????
Old May 15, 2016 | 06:21 AM
fokeyman's Avatar
Car: 89 IROC
Engine: l98 350 TPI
Axle/Gears: 373s
Re: Idle goes up when ALDL is connected ; Camaro 305 TPI
This should help. Post 72.
Old May 15, 2016 | 09:03 AM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
thats normal for the idle to raise, there should be a little resistor on the cable that you remove once the car is connected to the program, it should drop the idle back down
Old May 15, 2016 | 10:48 AM
thtanner's Avatar
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
This.
Once the car has begun to stream data, remove the 10k resistor (if you bought a premade cable it's gonna be a toggle switch/etc). The car should continue to stream data but will act normally.
Old May 16, 2016 | 03:46 PM
fokeyman's Avatar
Car: 89 IROC
Engine: l98 350 TPI
Axle/Gears: 373s
I for one thought the 10k resistor had to stay in. Thanks for the info, next data log I'll pull that out and have a nice running car AND data.
Old May 19, 2016 | 02:09 PM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Transmission: T5 Manual
Don't log with the resistor in place as it messes with timing. I did and it pings like mad.. not good.
