unplug IAC and nothing happens
Old May 28, 2016 | 02:12 PM
eddie jr's Avatar
If you unplug the IAC while running what should be the result? When i unplug it, nothing happens, it idles just the same (a little rough). Does this indicate anything or is that normal for the IAC.
Old May 28, 2016 | 02:16 PM
thtanner's Avatar
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
Re: unplug IAC and nothing happens
Did you unplug the IAC while the car was cold and it was regulating the idle?
Old May 28, 2016 | 04:47 PM
eddie jr's Avatar
it was warm or pretty warm anyway cuz everything was hot in the area.
Old May 28, 2016 | 09:41 PM
thtanner's Avatar
IAC does a lot of work when the car is cold / warming up.
What lead you to disconnecting it in the first place?
Old May 28, 2016 | 09:50 PM
someone972's Avatar
Car: 1991 Firebird Formula
Engine: 5.7L TPI
Also note that the IAC valve will stay in the same position as wherever it was you unplugged it, so I would expect that if you're already warmed up the idle shouldn't change at all when you unplug it.
Old May 29, 2016 | 12:23 AM
eddie jr's Avatar
that makes sense.
I had a rougher idle i was trying to troubleshoot.
gresmi
Jan 18, 2018 10:48 AM
Donald Croes
Jun 29, 2016 09:20 AM
KingHD
May 26, 2016 05:15 PM
PurelyPMD
May 24, 2016 09:32 PM
Zylinder
May 19, 2016 02:09 PM
