THOUGHTS AND INFO PLEASE
Old May 30, 2016 | 08:44 PM
HARDRIDER92's Avatar
first off hello every one im new to the site. i have a 91 z28 tpi that ive owned for 8 years car has a 290hp crate bottom end, mild cam in which i can not remember the profile, and ported and polished heads, and ported lower intake plenum, ported and polished intake runners and upper plenum, desnorkeled air box k&n filters accell distributor and 8.8 wires and plaitnum acdelco plugs,has corvette fuel rails and adjustable pressure regulator has hypertech chip, shift kit and 4.11 posi. still has factory manifolds and cats, (next to go) has 3in from cats back.
does any one have more ideas where to go next, car runs great lots of power and speed im just lookin for more with out going ls1 swap
Old May 31, 2016 | 10:43 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: THOUGHTS AND INFO PLEASE
If you're happy with the performance, then there is no reason to go into the engine for upgrades. Save up for a D1SC from Procharger, then invest in an EBL-P4 to control boost. Would be an extremely neat and clean install, and, depending on how much boost you run, will just about double your power output. Nice looking car by he way...
Welcome aboard.
- Rob
Old May 31, 2016 | 01:05 PM
i have thought about a little about boosting just not sure about reliabilaty all i do with the car is normal fluid changes and tune up and put gas in i have no problems doing any work on the car i know my way around inside motors quite well and i would run as much boost as possible
Old May 31, 2016 | 01:16 PM
Nice thing about the EBL-P4 is it is essentially a Flash oriented system, installs in the factory location, and you can tune on the fly. I went with one and will never turn back to burning proms, and boost is a breeze; 2 Bar, 3 Bar, you name it. Controls everything your stock ECM does, but no more chips, and with many more features...
http://dynamicefi.com/EBL_P4_Flash.php
gt4373
Mar 23, 2016 11:09 PM
gt4373
Mar 22, 2016 11:08 PM
gt4373
Mar 22, 2016 11:07 PM
chanrahan
Mar 21, 2016 09:53 PM
gt4373
Mar 15, 2016 12:59 PM
