Fuel injector ohm testing
Old Jun 11, 2016 | 12:51 PM
chevyhotrod's Avatar
Car: 1992 Z28
Transmission: manual
Axle/Gears: 3:42
I just did a ohm test on my 92 z28 305 tpi fuel injectors. On the drivers side my injectors all read 20.2 or 20.3 ohms.
On the passenger side the front 3 were 16.6 and back injector was 6 ohms.
Should I be concerned about the 20 ohm readings or only the 6 ohm reading.
My car has running rich and idles rough, could the injectors cause these issues?
Old Jun 11, 2016 | 02:11 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Fuel injector ohm testing
Stick a fork in them, they're done.
RBob.
Old Jun 11, 2016 | 08:03 PM
zero13's Avatar
Car: 91 Z28
Engine: Enhanced 5.0L
Axle/Gears: 3:42 Posi
This^^^^.
86ZRESTO
May 21, 2018 08:33 AM
IROC AND ROLL
Mar 29, 2016 09:52 AM
jakemack96
Mar 29, 2016 09:23 AM
scarr001
Mar 25, 2016 10:50 AM
86IROC112
Mar 24, 2016 10:00 AM
