Throttle body coolant bypass question
Old Jul 4, 2016 | 03:29 PM
I_R_O_C_Z_2_8's Avatar
Car: 1991 Trans Am GTA
Engine: 350 tpi
What's up guys I had a quick question I was going to do the tb bypass on my caresume but since I don't have the heater valve do I just plug the port on the Intake?
Old Jul 4, 2016 | 04:32 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
Re: Throttle body coolant bypass question
You don't plug the port on the intake manifold, that port is connected to the coolant send line that would normally route through the throttlebody which would be the line with the new hose clamp directly under the throttle positioning sensor in that picture you posted. you're just connecting the two lines with a fitting instead of connecting both lines to the throttle body.
Old Jul 4, 2016 | 05:00 PM
Engine: 350 tpi
Got it ok cause that line that goes into the tb comes from my radiator they cancelled the heater line and ran it from my radiator to the tb.
transamaster
Apr 30, 2016 08:19 PM
BillyW.
Apr 26, 2016 06:16 PM
tcrisp
Apr 24, 2016 08:51 PM
trafficlightguy
Apr 19, 2016 09:01 AM
89 formula TPI
Apr 17, 2016 09:06 AM
