Is there any V-6 TPI kits?
Old Dec 26, 2001 | 04:21 PM
1991v6camarors's Avatar
dumb question but is there, besides the ram jet setup used on the turbo buicks?
Old Dec 26, 2001 | 05:43 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Some of the 3800 series 1 engines (around 89 - 91) were actually called TPIs and they have some wording on the plastic injector covers to that effect........ They came in most of the Olds and Buick FWD sedans. But the intake really doesn't look like the TPIs on the LB9s and L98s..... It is a Long Tube Runner setup though.... I would have to categorize the 3.8LTurbo (GN, GNX, T-type, TTA) engine's intake as a non-LTR design since the intake runners really aren't very long. The design is very close to a Miniram/LT1 style..... There's really no sense in having long-a$$ed runners on those engines since they make some crazy torque (when spooled up properly of course).
Old Dec 29, 2001 | 10:02 PM
rockind78's Avatar
Matt is right. If you want to convert your V6 to TPI, you should check out the 3800's, but I personally can't tell you for a fact if it will fit. If it doesn't, you might have to look into something else.
Old Dec 30, 2001 | 05:15 PM
Matt87GTA's Avatar
Yeah, I doubt that the 3800 TPI stuff will work on a 2.8/3.1/3.4 style V6 without some serious fabbing - if at all. The 2.8/3.1/3.4 are kind of a different design since they are a 60* V6 and have a very unique intake manifold setup.
stalkier
Dec 6, 2015 11:25 PM
toronto formula
Nov 10, 2015 06:17 AM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
