need step by step on how to time Ignition
Old Dec 26, 2001 | 08:30 PM
87POSGTA's Avatar
Car: 1989 Firebird
Engine: 5.7 Vortec HSR
Axle/Gears: 9-bolt 3.45
topic explains it all. need to reset my ignition timing due to my stupidity. need a step by step on how to doit. also i need to reset minimum air ,TPS, etc. wondering if i need the motor timed first & how far should i advance it. got an accel ignition with some brand new moroso bluemax wires & platinum plugs gapped at .040
Old Dec 28, 2001 | 09:42 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Step by step starting where?? are you off a few degrees or did you take your dist out?
-- Joe
www.joesperformance.com
Old Dec 29, 2001 | 12:58 AM
87POSGTA's Avatar
Car: 1989 Firebird
the timing has totally screwed the pooch. I was playin around with the timing cause my car was runnin like crap. i swapped the ECM & EPROM from my other GTA, changed the injectors, and had the FP changed 3 times (3rd time i dropped the tank & found about 1/2 an inch of sand in my tank). so now everything is pretty much out of specs but i got good pressure & flow. So now i just need to time the car. was also wondering if i should turn the idle air torx screw a bit more open just in case i have that messed up too.
Old Dec 29, 2001 | 10:48 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Well Turn your motor with a wrench until your harmonic balancer line lines up with 0, then check your dist and make sure the rotor points to the #1 cyl. (front, driver side)
If it doesn't, pull it out, and spin it until it does and seat it back in. Then advance it a little with the light..
If you can't see your balancer, pull the #1 plug out, and crank the motor by hand until the #1 hole farts. (both valves closed). Don't turn it past the fart. That's "top dead center".
-- Joe
Old Dec 29, 2001 | 11:26 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I'm guessing the distributor is in okay and you were just moving it around?
Start the engine, disconnect the EST bypass connector, and with the timing light hooked up to the #1 Cyl, shoot the light at the HB and rotate the distributor until you have the mark lined up to where you want..should be at about 6* BTDC.
Shut the engine off and tighten hold down bolt, then reconnect the EST bypass connector.
Old Dec 29, 2001 | 11:39 PM
87POSGTA's Avatar
Car: 1989 Firebird
well, i have no clue where the EST by-pass connecter is. ive got a single wire weather pack connecter on my pass side but in my haynes it says it should be near the power brake booster. can u just disconnect the 4-wire plug going to the distributor? if need be i can take pics. Im gonna try the EST/4 wire route first then if i cant do that im gonna try for your way anesthes. if so should i pick up a TDC locator to make it easier?
Old Dec 30, 2001 | 10:15 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
On my IROC the EST Bypass connector is near the pass side strut tower, single wire connector..tan w/black stripe??..IIRC
Old Dec 30, 2001 | 03:19 PM
87POSGTA's Avatar
Car: 1989 Firebird
woo! got it set at 7* and shes runnin great! until i get that damn code 33 once i reach operating temp it also set a code 42 but thats normal right??hope so. 8mike9 and anesthes thanks for helping me. i appreciate it.
Old Dec 30, 2001 | 07:48 PM
rezinn's Avatar
The code 33 is a high voltage/low vaccuum at the MAF sensor. Check for a vaccuum leak around the sensor, or replace the MAF relays. Hopefully it is not the sensor. The 42 is from having the EST unplugged, that is normal.
Ghettobird52
Jul 5, 2024 11:18 PM
89GTAOz
May 16, 2020 09:31 AM
Fast355
Dec 2, 2016 06:33 PM
Bryan F
Aug 18, 2015 02:28 PM
