How did you gut your MAF?
Old Dec 24, 2001 | 11:33 PM
lancer5067's Avatar
I did the research on here before I asked and I am looking for ways to remove the cooling fins. I already removed the screens and am definately removing the fins also. One person wrote to use a hacksaw. I don't see this being feasible, I have an electric rotary tool but the fins are way too long to use it. I have the wire housing duct taped off and am seriously considering a hammer and small chisel to tap/cut the fins out. Any draw backs to this, like the direct banging?? What options do I have?? Thanks!
Old Dec 25, 2001 | 12:15 AM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
I used my Sears electric reciprocating saw with a metal cutting blade and sawed the fins off in a few minutes. Then used my Mikita high speed grinder to smooth things out.
Jake
Old Dec 25, 2001 | 03:04 AM
rezinn's Avatar
I could see using a hacksaw.. just assemble the saw with the blade inside the MAF housing, then use a drill or a dremel and a sandpaper wheel or a iron oxide bit to smooth it down. Easy poor mans way.
Old Dec 25, 2001 | 09:08 AM
69TPI383's Avatar
I took the hacksaw blade out and wrapped duct tape around a section of it for a handle. I then used my dremel to smooth them out.
Old Dec 26, 2001 | 12:23 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
Won’t the electronics in the MAF overheat without those cooling fins? That’s what they are there for.
Old Dec 26, 2001 | 12:33 AM
Guest
Guest
Posts: n/a
Someone here had a theory about those 'cooling' fins in the MAF that I thought was rather funny and probably has a fair amount of truth to it. GM probably took a car to Death Valley and parked the front end right up to a wall with the fans off and overheated the electronics in the MAF, so they added fins.
I havent heard of anyone who cut the fins saying their MAF electronics melted. Im sure there is always a chance though.
Old Dec 26, 2001 | 12:53 AM
69TPI383's Avatar
Madmax....I've read that in a few places as well...might be fact or fiction, who knows. But I believed it so much, I relieved my MAF of em
Old Dec 26, 2001 | 10:38 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
It went something like this....
GM was testing in death valley. When they ran the car at WOT, then stopped and shut it off, a couple of the MAFs failed. So, if you go to death valley, run wide open, and then stop for a picnic, you MIGHT be in trouble........
LOL. Can you say "overengineered"??
Old Dec 30, 2001 | 01:38 PM
bigals87z28's Avatar
Car: Check The Sig
hey guys
i was reading all of this stuff on the maf and cutting out the screans/fins what does cutting out the screans do? y are they there? what are the benifits? thanks!
Old Dec 30, 2001 | 02:12 PM
Guest
Guest
Posts: n/a
Before you run off and do it, read the name of the poster of this thread. Now read the name of the poster of this thread:
https://www.thirdgen.org/techbb2/sho...threadid=73879
If you do it, be careful. Benefits on an otherwise stock car are probably minimal, but it can be helpful on higher HP stuff. Your choice. My screens are gone and have been for quite some time, and I have done it on more than a few MAF's. Some are not so lucky, dont know why.
If you do a search of MAF screens you will find a whole bunch of posts with pros and cons.
Old Dec 30, 2001 | 08:22 PM
87transam5.7tpi's Avatar
Does anybody know if any companys make high flo MAF sensors for third gen. cars? I can only find ones for 93s and up.
Old Dec 30, 2001 | 09:27 PM
injdinjn's Avatar
Car: 1986 Grand Prix TPI
Transmission: 200 4R
The only 'high flow' MAF is the replacement one Wells sells. There is no aftermarket MAFs for thirdgens, never has been, probably never will be.
Mark_ZZ3
May 24, 2018 01:02 PM
BumpaD82
Feb 26, 2016 02:57 PM
racereese
Oct 3, 2015 03:46 PM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
