SuperRam on stock L98 - Injectors?
Old Jul 19, 2016 | 12:33 AM
thtanner's Avatar
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
I'm going to be putting on a SuperRam manifold base, plenum and runners on my stock L98 (has highflow dual cats & catback exhaust). I'm not expecting a world of gain or anything, but will be revisiting the motor later with heads, cam, etc.
So for a stock head/cam setup, would 22lb injectors be sufficient with the extra airflow that will be made available? I have B III's from SouthBay currently. I've considered going 24lb injectors and then tuning, since I have to use a non-adjustable FPR due to Cali smog restrictions.
Feedback would be appreciated. I'm totally expecting a few "why" posts, but I'll just say "why not".
Old Jul 19, 2016 | 12:43 AM
Vanilla Ice's Avatar
Car: 92 Trans Am Conv
Engine: LB9
Axle/Gears: 3.08
Re: SuperRam on stock L98 - Injectors?
Depends on who's tuning the car. You could easily be fine. Just want to watch afr at wot at shift point. I'd do it. If there was an issue look for some bodies throw away stock lt1 injectors.
Old Jul 19, 2016 | 07:18 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Use stock for now and upgrade later. You would likely have to retune with new injectors moreso than with the intake but even tuning with those bolt ons it would show improvements
Old Jul 19, 2016 | 10:15 AM
thtanner's Avatar
Thanks guys. Wasn't looking to spend money for fun/make work where there is none, so I'll re-approach injectors when I do the rest of the engine mods.
Old Jul 19, 2016 | 10:16 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
The ECM has O2 correction, but the idea is to keep that margin close and within it's range. Ask yourself how much horsepower the Super Ram will uncork, then calculate how much horsepower the 22# injectors can handle, which is about 285 horsepower at 80% duty cycle, and about 350 horsepower at 100% duty cycle. The Super Ram itself will not net you 100 horsepower as a bolt on so your injectors are fine. However, the VE down low will be "moved around" so to speak, and this is where the O2 correction comes into play. If the margin is too great in some areas you will feel it during everyday driving, as well as during the transition into power enrichment, which will greatly affect your wide open throttle fueling if BLM is higher than 128 during that transition. If you can live with it, you will be fine, but like Vanilla Ice pointed out, watch your fueling up top...
Old Jul 19, 2016 | 10:27 AM
thtanner's Avatar
Cheers for the detailed reply. My goal is to datalog + retune after (if my usual tuner will do it; he seemed not-so-keen on the SuperRam on the stock engine. Said I'd get loss down low, but other threads, articles and dyno sheets seemed to show that I'd be fine if tuned).
The 'why not' was geared towards people asking 'why put the SuperRam on a stock engine' since it seemed to come up any time someone asked in the past. Will be doing a dyno run before and after to see what is what.
Old Jul 19, 2016 | 11:13 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Super ram and 1.6 rockers on a stock engine will gain alot of power! Been there done that. Drop near half sec off 1/4 mile from stock with those two mods easy. Abit more with tune and simple suspension mods/weight reduction with drag wheels. Its possible to make a stock low 14 sec L98 car turn high 12's with all the bolt ons. Stock 22 lb is fine
Old Jul 20, 2016 | 12:24 AM
thtanner's Avatar
Thanks again for all the helpful info, same with VI and SL
Old Jul 5, 2022 | 11:20 PM
Richard Endress's Avatar
Car: 1987 Corvette C4 Coupe
Engine: 350 ci /5.7 L L98 V-8
Transmission: Doug Nash 4+3 manual
So how did it all shake out? I am collecting parts for a similar upgrade on an L98 in an '87 corvette. I originally came upon this thread while considering 24 lb. injectors. How much did you ultimately change. Did you go with the Super ram? Cam, heads? Did you get on a Dyno?
Old Jul 21, 2022 | 10:41 PM
Bigscott's Avatar
You noticed a big gain from the super ram? I have 92 formula 5.7 that I want to do the super ram on. I have headers,3' exhaust no cats and a flow master. CAI, Air foil, no smog equipment. It runs good now has good power down low. But falls flat after about 60. What did you run the 1/4 in? after the Ram and rockers?
Orr89RocZ
Sep 2, 2016 11:19 PM
Bullydawg
Aug 3, 2016 08:31 PM
89-S-dime
Jul 19, 2016 11:06 AM
chazman
Jul 19, 2016 12:18 AM
MSgt Luttrell
Wheels and Tires
Jul 16, 2016 07:53 PM
