'86 Camaro hard start/shuts off
Old Aug 14, 2016 | 02:33 PM
sulvoreth's Avatar
Car: 1986 Camaro Iroc-Z
Hey guys. Ive been looking through the forums a little bit and can't really find a solution to the problem i have. I have a '86 Iroc-Z with the 305 TPI. Owned it for about 8 years now. I drive on occasion but probably not enough as i should. Anyway.
When I let the car sit, It'll fire right up. If I drive it then go to start it, sometimes it just cranks and cranks then fires. It then runs fine.
Another problem I just started having is the car will drop in rpm's in idle and sometimes stall. Sometimes it shuts off in gear idling as well. I did notice when I start it, the alternator will whine/squeal until the volt gauge goes above 13 then will stop.
I cleaned the throttle body and MAF since i got a check engine light for lean exhaust (if i read the code right) Car seems to run a lot better and only shut off once since. I have a new alternator to put on, but unsure if thats where my problem is coming from.
Any insight will be appreciated. Thanks!!
Old Aug 16, 2016 | 02:15 PM
maks10's Avatar
Car: 1990 Trans Am
Engine: 5.7 350 HSR afr195 xfi268
Axle/Gears: 3.08 posi
Re: '86 Camaro hard start/shuts off
Maybe start by checking fuel pressure and ohm injectors
Old Aug 16, 2016 | 03:03 PM
sulvoreth's Avatar
I just had the fuel pressure checked and it was good cause i thought the pump was going out. I didnt check the injectors yet. thank you!
Bowtieman1970
Aug 17, 2016 02:50 AM
evo-offer
Apr 2, 2016 04:42 PM
krisb410
Mar 17, 2016 05:51 PM
vash90909
Mar 13, 2016 07:56 PM
Smash
Aftermarket Product Review
Sep 20, 2000 08:03 AM
