ID Engine year- Locating Numbers
Old Sep 19, 2016 | 10:59 AM
Ming's Avatar
Have a Chevy engine, was told it was a 1991 Corvette 350. Cant locate any engine stamped numbers that jive with posted info. The casting on the drivers side rear reads : GM 5.7 L G and SGI under the "GM", passenger side by water pump has a "CC5 110", no other stamps on the block that I can find. Asked my local dealer , they don't have a clue... The "CC5 110" doesn't correspond to crate engine numbers that i could find on the web. The engine has cast iron heads, so that pretty much tells me its not a Corvette, maybe a Camero ?
Any ideas
Tsk
Old Sep 19, 2016 | 11:31 AM
rarebmx's Avatar
Car: 89 IROC/89 Vert/87 Vert/89 GTA Vert
Engine: 5.7/5.0/5.0/5.7
Axle/Gears: 9" 2.77/9" 3:23/9" 3:42
Re: ID Engine year- Locating Numbers
http://www.nastyz28.com/chevy-engine-code-stampings.php
Old Sep 20, 2016 | 11:25 AM
navy02ws6's Avatar
Engine: LS1, LB9, L03
https://www.thirdgen.org/forums/tpi/...ine-block.html
Old Sep 20, 2016 | 11:34 AM
Ming's Avatar
My stamped digits on the pad near the water pump passenger side don't jive with anything I've found on any forums or websites, its CC5 110, nothing else.
Old Sep 20, 2016 | 07:07 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Take a photo of the stamping on that pad and post it, please.
Old Sep 20, 2016 | 07:25 PM
rarebmx's Avatar
Which should mean a crate engine. So "Corvette" had a crate engine. No VIN stamping shouldn't be able to be looked up. You'll have to find crate engine stamping codes.
Old Sep 21, 2016 | 05:30 AM
Ming's Avatar
Photo attached of the stamping code , passenger side below head by water pump
Old Sep 21, 2016 | 09:43 AM
rarebmx's Avatar
I have read elsewhere that on crate engines that no sure way to identify what they are/were. The stamping is only a partial GM part #. Every factory engine I've ever seen have the date coding as well as partial VIN.
I'd at least remove the valve covers & see what heads.
You're probably going to have to tear ir down to figure out what it really is.
Old Sep 21, 2016 | 12:43 PM
navy02ws6's Avatar
Either that's not a factory GM engine, or the stamp pad has been decked and restamped by an engine shop. The VIN is missing, as well as the plant code, assembly date, and suffix. With that being said, there's no way to tell EXACTLY what it came in originally. You can still look at the casting number and casting date to narrow it down a bit, but the important part (stamp pad) is gone if it is indeed a factory GM engine.
1BADZ28SD
Sep 12, 2016 12:57 PM
Gangsta Stude
Sep 7, 2016 07:09 PM
Z-Firebird
Sep 3, 2016 01:39 PM
armybyrd
Aug 31, 2016 12:35 AM
birdman_29
Aug 29, 2016 04:38 PM
