Intermittent code 33 maf
Old Dec 31, 2016 | 06:33 PM
Lethalv6's Avatar
Car: 1986 IROC Z28
Transmission: auto
a few weeks ago I had a code 34, but also found a massive vacuum leak on one of the intake runners so fixed that and car runs great. Then dealt with a code 42 and no spark advance...changed the icm and I have that fixed. Car was running great then dies, it fired a code 33 and wouldn't restart..unplugged the maf and it started up. I unplugged the batt to clear codes, restarted with maf plugged in and no code and it runs...check the scanner and gm/sec air at idle is 8, I rev up some and let it run and 5 min later the code comes back and it's barely running..gm/sec drops to 6, then 5 and it dies. I switched the maf before but figured the vac leak caused that code...I hate to go rebuy the maf again but I can't figure what else might cause this, it was running great and out of nowhere the code goes on and off with restarts.
Before I go buy this maf again I figured I'd ask for advice.
Thanks again,
Old Dec 31, 2016 | 08:32 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Intermittent code 33 maf
The grams per second are right on.
Code 33 sets when flow exceeds 45 gps below 2k rpm and 1/4 throttle.
The ecm has a 5v pull-up on the signal wire. If the signal voltage is 2.2v or higher for 1 second code 33 will throw.
Old Jan 1, 2017 | 08:00 AM
Fire"Dutch"Bird's Avatar
Car: '88 Firebird Formula 350
Engine: 350 (5.7 TPI)
Transmission: auto 700R4
Axle/Gears: BW 9-bolt L.S.
I had these codes ( 33, 34 etc.) for a long time, turned out to be a bad connection in the fuel pump relay harness...
http://www.ebay.com/itm/85-89-Camaro...RRroGU&vxp=mtr
Old Jan 1, 2017 | 09:54 AM
Lethalv6's Avatar
Car: 1986 IROC Z28
Transmission: auto
Is the fuel pump relay the odd bird of the 3 on the firewall by the brake booster ? I cleaned the other two matching relays when my 34 reared its head, I don't think I cleaned the third one. I also read it could be relay issues ? Those are $15 a pic, not terrible but this being intermittent makes me hesitant to buy a rebuilt $150 maf if the problem will still show up. I appreciate all you folks info and patience with me, I'm pretty excited the cars almost road worthy.
Never mind, I looked it and it appears it's one of the two I cleaned out but there appears to be 2 others that have to do with the maf that I didn't touch, I may try cleaning those...this thing sat for a long time, there's age gremilins galore.
Old Jan 1, 2017 | 10:03 AM
It's the middle one, at my car at least, but it's the relay with the wires like in the picture above.
Old Jan 1, 2017 | 07:13 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Thanks again,
i have found that in a lot of cases , the power and burn off relays are wrong / weak/ dead . that and the wiring going to and from the TPI . and i must point out that the MAF sensors on the market are of poor quality . and some fail right out of the box . i had good sucess with "rich porter " . but i cant find them anymore . the thing to stay FAR away from is the "cardone " and "airtex " POS . hope this helps
Old Jan 1, 2017 | 08:25 PM
Lethalv6's Avatar
Car: 1986 IROC Z28
Transmission: auto
Thanks guys, I'm going to clean these relays up and see what happens, the only mafs I can find are those exact brands you named...I'd be really angry to spend that money and it not fix. I still have suspension, brakes, int. and paint on this thing. I'll def report back. The power and burn off relays are the far right two by the fender correct ? I have read a few diff posts on their location.
Old Jan 1, 2017 | 09:16 PM
Engine: Lb9
Transmission: M20
You can usually get a used 86-89 maf used in the classifieds for $50-60 or so.
I have programmed the code 33 threshold higher for guys running larger cams and a few people that can't get the error to go away. Hope it's a simple fix so you can move onto other things.
Old Jan 4, 2017 | 10:29 AM
Car: 86 IROC
Engine: 5.0 TPI
i wouldnt waste time cleaning relays . just make sure the right relays are in the right position. and yes , man is it ever hard to find a working MAF . makes me want to convert my 86 to speed density , and be done with all that BS
Old Jan 7, 2017 | 04:19 PM
Lethalv6's Avatar
Car: 1986 IROC Z28
Transmission: auto
Excellent info ! I replaced the relays with new bw pcs from oreilly and ran a new iat sensor and rerouted to the air box, now that reads correctly and no more code 33. Now I'm on to brakes...thanks again for all your help.
Old Jan 7, 2017 | 07:27 PM
Engine: Lb9
Transmission: M20
