would i need to change the PCM?
Old Dec 30, 2001 | 12:01 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
i am looking at a 1990 IROC 305 TPI with VERY high mileage
the body is in great shape and the price is only $1500
i would like to swap out the 305 long block for a 350 long block
will this make the PCM go nuts? if so, is it a straight change to a 350 TPI PCM?
i will also need 350 injectors, right?
Old Dec 30, 2001 | 04:02 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
For the third gen they're called ECMs. You won't need to change the ECM, but you will need to change the memcal and injectors. An even better idea would be to burn your own chip, along with using the appropriately-sized injectors. The 5.7L also uses a different knock sensor and EST module, so keep that in mind as well. Everything else should swap over just fine.
bryanwood74
Sep 24, 2015 09:50 PM
BAMiller
Sep 14, 2015 06:38 PM
z28guy134
Sep 1, 2015 11:50 PM
NBrehm
Aug 25, 2015 11:49 PM
mizz0313
Aug 12, 2015 06:45 AM
