Unkown Injector
Unkown Injector
Hello togehter,
have a unkown Injector 01D041B, Range 2-4.5 bar (16,7 Ohm).
Anyone can tell me if this fits for a `91 5.0L TPI "F"??
Car smells unburned gas and has a BLM of 150-160
Danny
Danny
Car: check
Engine: check
Transmission: check
Re: Unkown Injector
That is a Lucas part number. From the Stan Weiss list it appears to be a 19 #/hr injector at 43.5 psi fuel pressure.
The BLM of 150-160 is adding a lot of fuel. If there is truly a lot of unburned fuel look into the O2 sensor feedback. That is what the ECM uses to adjust the fueling.
RBob.
RBob.
Re: Unkown Injector
Also have Code 43, maybe the reason for the high BLM is from there?????
I know it´s a cheap knock sensor (will change this week).
ECM ACDELCO Remanufactured.......Prom ARZU...(will change to AXXF).
Car: 1988 IROC-Z
Transmission: T56 swap ongoing
Axle/Gears: 2.77 9-bolt Posi
Re: Unkown Injector
If you're only running 30 PSI, you need to address that first. It's going to run lean, and attempt to hold the injector open longer to make up for the reduced fuel being fed into the engine. That's at least one of the reasons BLM is so high.
I can't make a blanket statement that's ALL of the issues, but until the fuel pressure issue is resolved, it's going to be all but impossible to find any other lurking problems.
Car: 1988 IROC-Z
Re: Unkown Injector
That's not surprising, or unusual. I can't remember ever encountering a good, or accurate Haynes manual. One of the first purchases I make is the factory service manual..in a pinch, I've used Alldata, which looks to be an excerpt of the factory manual.
Try this for resistance specs.
https://www.thirdgen.org/forums/atta...le-2_21_01.pdf
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Unkown Injector
Maybe I'm incorrect
