1991 TPI Vacuum hoses
I bought a 91 Trans Am with the 305. The previous owner disconnected some of the vacuum hoses and I am not sure where they go. I have photos if anyone is interested in helping me figure it out.
Thank you
Thank you
Transmission: Pro-built 700R4
Re: 1991 TPI Vacuum hoses
The first pic is where the EGR solenoid connects. The two vacuum lines are the hard plastic kind. One should connect to the EGR valve and the other runs up underneath the plenum to a small port on the bottom of the throttle body on the driver's side.
Thanks again!
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
The diverter valve diagram is here
https://www.thirdgen.org/forums/tech...iagrams-i.html
beachliving
Oct 7, 2016 07:59 PM
theformula
Aftermarket Product Review
Oct 15, 2000 08:49 PM
