Anyone running Comp Cams 08-501-8 in L98?
Old May 18, 2017 | 04:54 AM
amfornal's Avatar
Car: 1989 IROC Z L98 G92
Engine: 5.7
Axle/Gears: 3.27 G92
Anyone running Comp Cams 08-501-8 in L98? I have this cam in my 1989 L98 IROC-Z. Right now I am running this cam with ported intake and Magnaflow Dual Cat-back exhaust. This cam really woke up my stock L98. My question is what other Mods can I do that will get me the best bang for the buck. I would like to go with new heads, headers etc. but I don't know what the limitations of the Cam I already have put in are. Anyone have any suggestions on heads, rocker arms or anything else to get some more HP?
Comp Cams 08-501-8
Basic Operating RPM Range: 1,200-5,200
Intake Duration at 050 inch Lift: 212
Exhaust Duration at 050 inch Lift: 218
Duration at 050 inch Lift: 212 int./218 exh.
Advertised Intake Duration: 264
Advertised Exhaust Duration: 269
Advertised Duration: 264 int./269 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.488 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.495 in.
Valve Lift with Factory Rocker Arm Ratio: 0.488 int./0.495 exh.
Lobe Separation (degrees): 112
Old May 18, 2017 | 07:30 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Anyone running Comp Cams 08-501-8 in L98?
It would do better with headers and big tube intake runners or especially a shorter runner intake. Siamesed runners or aftermarket intake manifold
Old May 18, 2017 | 07:48 AM
ULTM8Z's Avatar
That's the cam I'm running.
As Orr89RocZ said, it does really well with my short runner Miniram. The advertised 5200 rpm limit seems to be a little conservative since for me the engine pulls hard to at least 6000 rpm. It's a very good street cam with very good street manners... smooth idle, hauls a$$, and gets ~27 mpg highway (with ECM's highway mode dialed in and overdrive + 3.42 axle ratio).
Old May 18, 2017 | 08:55 AM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Currently running that cam on a factory intake and 083 heads. Still has good power. Can't wait to put my ported set up on in and see how much much I am currently missing out on.
Old May 18, 2017 | 10:37 AM
hrspwr's Avatar
Car: 86 IROC
Engine: 350 Vortec TPI
Axle/Gears: BW 3.27
Running it as well, but with a TPI intake and now a SuperRam.
Old May 18, 2017 | 10:45 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Don't forget you will need to tune for the cam swap to optimize performance. IMO best being for the buck.
Old May 18, 2017 | 01:25 PM
ULTM8Z's Avatar
yeah, should be a very easy cam to tune for. Probably some minor changes to VE/spark and the PE. Though, a WB O2 is highly advisable to tuning the PE.
Old May 19, 2017 | 02:16 AM
amfornal's Avatar
Engine: 5.7
I forgot to say that my car is tuned for this cam and I have mildly ported the TPI lower intake as well as the upper plenum and enlarged TPI factory runners.
I guess I should rephrase my question. Would a new set of heads/ rockers, springs be worth investing in already having this CAM installed? Would I see a good increase in HP?
Old May 19, 2017 | 07:01 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
You would see good hp with heads AND intake mods. Whole system needs to flow. Heads alone will likely only make a few more hp due to limitations in the tpi intake
