RELAY #'s for; Fuel Pump, MAf Burnoff, MAF Power, MAF Sensor, ECM & PROM
Old May 30, 2017 | 02:17 PM
OUR_ZED's Avatar
1988 IROC-Z 505l TPI w/AT. It was built in Van Nuys CA USA for Export to Canada.
What are the replacements numbers NOW as most likely original numbers are discontinued?
Problem is trying to resolve a intermittent SEL. There is no change in engine except light comes and goes. Sometimes it's on at start-up and sometimes it's not. Can come come on while driving and later it goes off. Throws a code 34.
Old May 30, 2017 | 03:04 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: RELAY #'s for; Fuel Pump, MAf Burnoff, MAF Power, MAF Sensor, ECM & PROM
1227165 ecm
https://www.thirdgen.org/forums/tpi/...nces-they.html
http://www.chevythunder.com/maf_code_34.htm
http://chevythunder.com/prom_bcc_1988.htm
http://www.3rdgenformula.com/88/promcodes.htm
Old Jul 5, 2017 | 09:27 AM
ted-hurst's Avatar
Car: 30 Ford Coupe
Awesome, Thanks.
Old Jul 12, 2017 | 07:09 PM
Rebuildman's Avatar
Car: 1990 Corvette, 1985 C-10 1979 Subun
Engine: 350, 406 HSR
Transmission: manual, 200 4r
I have a bunch of the original used relays laying around, as I have replaced them all with the modern version, small square ones, four or five pin as needed. I have not had an issue using them but the connector will need to be changed. Good quality replacements using a diode across the contacts are more reliable.
onebadsc
Jul 20, 2017 03:07 PM
Henjoe
Jul 9, 2017 12:07 PM
redrummer
Nov 17, 2005 02:10 AM
Slow Iroc
May 3, 2001 07:10 PM
