VATS is BAD, How to bypass?
Old Apr 4, 2017 | 03:56 PM
Henjoe's Avatar
Car: 2 camaros, 1992 v6 /1984 350
Engine: 350 with holly carb swap to sniper
Transmission: Both are auto 700r4 both 1992
Axle/Gears: unknown
Hay all! first post here.
Anyway, Confirmed vats is bad, no crank, no fuel pressure, no security light. getting code 46, vats. tryed both of my keys, same thing, so its not the key cylinder, meening I cant just used a realy to skip it can i ? .-.
Also, to prove it, i un-pluged the 2 small orange wires going to the Vats, and it changed nothing meeneing, If it was something else, I would have gotten a security light for sure.
SOI did alot of reading. They say you need to bypass the vats relay, ANd get a new prom. I cant find a single hit on a new prom, so. I found this picture, showing how to basically, hot wire the car.
Tan and white wire from gear selection, and a yellow from column (pretty sure its the wire from the cylinder to engage the starter? and not yellow, thats the airbag wire, thatt i removed the airbag anyay. )
So
Anyone want to help me hot wire my car so i dont have to get a new prom lol?
Old Apr 4, 2017 | 04:44 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: VATS is BAD, How to bypass?
Post 13
https://www.thirdgen.org/forums/elec...-no-start.html
Old Apr 6, 2017 | 04:31 AM
Henjoe's Avatar
Axle/Gears: unknown
Thanks that information and some other things helped me get it going!
Old Apr 6, 2017 | 08:03 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Old Apr 6, 2017 | 09:49 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
You leave the car in the right neighborhood and they'll get it running for free. You just need to steel it back again, that's all.
Old Jul 8, 2017 | 05:56 PM
Henjoe's Avatar
Axle/Gears: unknown
Still having issues. I put in a new key cylinder which was the problem and it worked great.
Now its doing the exact same thing as before, VATS preventing a start even with a NEW key cylinder. AFTER it had worked for a couple days wdf?!
What can I do? New NEW key cylinder? idek so frustrated.
Old Jul 8, 2017 | 06:07 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
It's not usually the actual key cylinder that presents the problem, it's the skinny wires running through the column that get pinched or stretched or something until they break or no longer conduct the key value. To maintain the VATS security feature you need to route the wires more carefully, or just bypass the whole thing which loses the security function
Old Jul 9, 2017 | 12:07 PM
GeneralDisorder's Avatar
Just measure the distance of your key, and get this kit:
Amazon Amazon
Wire the appropriate resistor to the key chip wires coming out of the lock cylinder.
GD
