Distributor problems
Old Jun 19, 2017 | 08:24 PM
Matthewpeters41's Avatar
Hey guys, I'm new here in desperate need of some help. I bought an 89 formula 305 tpi. The guy I bought it from messed with the timing, and it's been a real son of a ***** to get it right. I moved the distributor a little, now it won't start. I get some coughs but won't fire. I'm very inexperienced with anything distributor/timing related. I don't have a timing light so I kinda have to go by ear once I get it started again. Any advice is much appreciated. Thanks guys!
Old Jun 20, 2017 | 12:23 AM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
Re: Distributor problems
First mark the distributor where the #1 cylinder plug wire is and remove the cap. Next remove the #1 sparkplug (driver's side front of engine). Have someone turn the engine over while you put your finger over the #1 plug hole. When you feel air pressure trying to push your finger off you're getting close to "top dead center" on the compression stroke.
Look at the rotor on the distributor and it should be pointing pretty close to the mark you made on the distributor. It also should be pointing at the physical location of the #1 cylinder. If the rotor is pointing the right way, but the mark on the distributor is a little off, line them back up. Put the cap back on and try to start it.
Do a youtube search on setting initial timing and you will see what I'm talking about.
Old Jun 20, 2017 | 03:02 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Once you get the engine to run. To set the timing the est connector must be disconnected. This is located on the rh side on the engine compartment bye the fan blower assembly. It's a tan with a blk stripe. Once disconned set the timing to 6-8 dbtdc.
