Warm engine, high idle, restart, it's just fine.
Old Jun 25, 2017 | 04:30 PM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
High idle, restart, it's just fine. Nothing else changed.
If it is running high, it will not come down to the correct idle with any coercion. Pedal, driving, gear, nothing. A simple, quick restart fixes it.
Seems that ECU initializes with it in this weird range. I'm thinking dirty connections? Is this a clear symptom of a particular fix?
Old Jul 7, 2017 | 04:45 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Warm engine, high idle, restart, it's just fine.
Sounds like a bad ecm. Iirc I've seen this in a old post.
Old Jul 7, 2017 | 04:47 PM
Engine: Lb9
Transmission: M20
https://www.thirdgen.org/forums/tpi/...-question.html
