South Bay Injectors
Old Jul 6, 2017 | 08:06 PM
brianlibby791's Avatar
Car: 1989 Trans Am GTA
Engine: 5.7L 350 TPI (Deleted Cats)
Axle/Gears: Original 3.27
South Bay Injectors
https://www.southbayfuelinjectors.co...ctors-bosch-d3
https://www.southbayfuelinjectors.co...-tpi-1985-1992
I was just wondering, what is the difference between these injectors? I understand one is 22lb and one 27lb, but is there any important difference i should know? They both say they work for the 350 tpi but i just dont understand why the "lb" is different.
Old Jul 6, 2017 | 10:53 PM
GeneralDisorder's Avatar
Re: South Bay Injectors
They flow different amounts of fuel. Which you may need if you have a modified engine. 350 TPI engines use 22 lb injectors stock. So you must use a 22 lb injector unless you reprogram the computer.
GD
Old Jul 7, 2017 | 08:46 AM
Abubaca's Avatar
The term "work" can mean two things. First, they'll "work" meaning they fit into the manifold, and they have the proper connector/pigtail. Second would be the pounds per hour. One is the factory 22 lb. per hour, the other is 27 of course. As mentioned, without tuning, you'll want the factory 22.
Let's say you put on a bigger heads. You now have more air coming into the engine. You need more fuel to go along with it. Hence larger injectors. ...but not needed for a bone stock engine with bone stock tuning.
Old Jul 7, 2017 | 07:48 PM
ULTM8Z's Avatar
GD
And you STILL may need to reprogram the computer even if you use the same flow rating.
https://www.thirdgen.org/forums/diy-...ctors-not.html
Old Jul 9, 2017 | 12:59 PM
I think it depends on what PROM and which code the car is running. I played with changing the battery offsets, etc and the factory settings really seemed to work better with the more stable BLM's so I went back.
I've put 22's on a 90 Vette with no programming at all and it worked fine.
All that said, there are people that don't have perfect results.
If you can change injectors, then you can get a programmer, some chips, and an old laptop and with some help from the forum you can make it work. Honestly people have no business messing around with anything on a computeized fuel injected engine if that can't or are unwilling to handle the computer side of the equation. If you can't take that on, then seek out direct replacement original parts. Even then you can get over your head with basic repairs if you can't make peace with the ECM and it's sensors.
GD
