HELP! TPI, what did I buy? Etc.
Old Sep 29, 2017 | 11:27 PM
Zipedoda's Avatar
Hi. Many places I looked said I would find answers from you guys. This, and future questions may have already been answered, but I'm new and haven't discovered the answers. A little background- I'm an old hot rodder who has worked on carb cars a loooonng time, but I wanted to jump into fuel injection. So i went out and found a TPI complete+ setup on Craigslist- manifold, fuel pump, 2 different wiring harnesses, and 2 different ECMs (along with associated sensors). I got this because: 1- I didn't want the TBI hiding under a stock-ish air cleaner look, 2- I couldn't afford the Hilborn look, and 3- this was cheap & I liked the look. I plan on installing this in a 1928 Ford Model A coupe. Now let the questions begin. But first-
How do I move pix from my album to this thread?
Old Sep 30, 2017 | 01:14 AM
Zipedoda's Avatar
Re: HELP! TPI, what did I buy? Etc.
Trying this by loading from my iPad. ECM- what year is it? MAF or SD? Info about the company on label? Any guesses on chip? 1st pic, bottom view. 2nd pic, connectors.
Attached Thumbnails HELP! TPI, what did I buy? Etc.-c8020d17-acb5-4b1b-a11f   HELP! TPI, what did I buy? Etc.-2523572b-d359-4289-b530
Old Sep 30, 2017 | 01:18 AM
Zipedoda's Avatar
PART 3. Trying this by loading from my iPad. ECM- what year is it? MAF or SD? Info about the company on label? Any guesses on chip? Any help please!
Pic 3- top of ECM. Pic 4- close up of PROM.
Attached Thumbnails HELP! TPI, what did I buy? Etc.-c3ec4fbc-871a-49a0-86d4   HELP! TPI, what did I buy? Etc.-150c1d72-813c-48e5-a5a8
Old Sep 30, 2017 | 01:30 AM
Zipedoda's Avatar
It’s gonna go in this.
All steel ‘28. Underneath- Mustang II coil over disc brake front end, Mustang 8” coil over rear end, SBC 350 c.i. 290 hp crate motor, turbo 400 trans, etc.
Attached Thumbnails HELP! TPI, what did I buy? Etc.-e4f85db7-5df7-4e8a-8069
Old Sep 30, 2017 | 01:35 AM
Twin_Turbo's Avatar
The ecm is a c4 corvette weatherpack ecm. Obviously custom tuned for a 383
It's engine bay mount... speed density
Old Sep 30, 2017 | 05:23 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
If you need help reprogramming the 727 ecm send me a pm
Old Sep 30, 2017 | 06:18 PM
Zipedoda's Avatar
Thanks for the replies. Now on to the next questions..... Do I have to re-burn the prom cuz it’s for a 383 and not a 350? Is there a place that can scan it to see what’s what? I assume that because it says off road that the vats has been disabled? Finally, what is the thing on the bottom and what does it do?
Attached Thumbnails HELP! TPI, what did I buy? Etc.-d1acec1c-afe4-4a11-9b1c   HELP! TPI, what did I buy? Etc.-25d0aa99-dbcf-4680-831e
Old Sep 30, 2017 | 06:25 PM
Engine: Lb9
Transmission: M20
It can be read but it would be best to start over with a tune. It might have egr air pump disabled. The other piece is a relay.
Old Sep 30, 2017 | 06:46 PM
Engine: Lb9
Transmission: M20
To elaborate, a 383 uses way larger injectors, the ve table will be to far off for a 350. Same thing with a unknown timing table. It’s better to start over . The relay could of been a fan or fuel pump relay.
Old Oct 1, 2017 | 01:34 AM
Zipedoda's Avatar
Thanks for all the replies guys.... now on to the next phase. As I said before a wiring harness came with it. That’s the long shot pic. There are a couple of connectors that I am unsure of... The connector in the 2nd goes to...? The connector in the 3rd pic goes to...? And there are individual connectors. Any ideas? I guess this was a no frills wiring harness for a stand alone install?
Attached Thumbnails HELP! TPI, what did I buy? Etc.-5f524f56-ac3f-44b3-95ce   HELP! TPI, what did I buy? Etc.-c9df947e-955a-4ec1-adcd   HELP! TPI, what did I buy? Etc.-4de4cddf-185b-4b8a-a248   HELP! TPI, what did I buy? Etc.-84206613-a106-4dee-9086
Old Oct 1, 2017 | 01:37 AM
Zipedoda's Avatar
Here are the connectors for the ecm n relay attached to it
Attached Thumbnails HELP! TPI, what did I buy? Etc.-22e17e25-d5f2-4041-a964
Old Oct 1, 2017 | 09:07 AM
Engine: Lb9
Transmission: M20
Cts or mat and distributor connector
http://www.chevythunder.com/199091_c...227727_ecm.htm
Old Oct 1, 2017 | 09:12 AM
Engine: Lb9
Transmission: M20
More schematics on the 1227727 ecm
http://www.gearhead-efi.com/Fuel-Inj...CM-information
