TPI on top of a GM 350 crate motor
I purchased a car from an estate and was initially told the engine was a 92 L98 from a Camaro. But as it turns out, it is a GM 350 crate motor. According to GM, based on the casting number 10066036, the short block could be 1973 to 1985 or 1986 to 1989. The heads, casting # is 33417369, are from 1990 or later. The TPI is from 1985 to 1988 since it has the cold start solenoid setup (previous owner put in a bypass toggle switch). The interesting issue is that the ECM, which I posted to the ECM forum, is supposedly for 1988 305. So I am wondering if there might be any issues or future issue with this engine, TPI, ECM combination. Also, what would be the difference between the GM head and the L98 head?
