ECM and chip - what do we have here
Old Dec 10, 2017 | 07:30 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
I have been fighting a slight overheating issue and decided to pop into the ECU and see what was there. The screws were loose and no velcro, so obviously someone had been there before. Attached is what I found.
Are these chips basically trash? I had one in my truck in the 90s and never noticed a difference so I sold it when ebay became popular. I have a burner now and thanks to this site, gearhead efi, moates can burn my own chips anyway. So is owning this chip pointless, even worth anything? lol
Also, interesting that it's a reman ECM. This car only has like 80k miles on it, I wonder would could have happened to have caused the original to die, unless there was a recall sometime after 1995.
Old Dec 11, 2017 | 10:52 AM
GeneralDisorder's Avatar
Re: ECM and chip - what do we have here
ECM's die. It happens. Cracked circuits boards or solder joints, etc.
Chip is junk. But you did get a free chip adapter! Score.
Pull the ROM off it and see what they did. I'm sure a few things were changed but off the shelf stuff like that tends to be conservative and generic for obvious reasons.
GD
Old Dec 11, 2017 | 11:38 AM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Good point (about the free adaptor). Here it is in case anyone wants to look inside the bin and compare. When I get time I will. 1992 350 TPI.
File Type: bin
Old Dec 11, 2017 | 01:15 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Attached are pics of the 2 changes to tables they made. Stock vs their change.
Along with the tables, they also:
Raise TCC lock low gears vehicle speed from 38 to 42
Raise TCC Unlock low gears vehicle speed from 36 to 40
Raise TCC Lock high gear vehicle speed from 38 to 42
Raise TCC unlock high gear vehicle speed from 36 to 40
Lower fan 1 disable temp from 104.74 to 73.25
Lower fan 1 enable temp from 107.75 to 80
Attached Thumbnails ECM and chip - what do we have here-stock-enrich-power-change   ECM and chip - what do we have here-hypertech-enrich-power-change   ECM and chip - what do we have here-stock-spark-advance-main.png   ECM and chip - what do we have here-hypertech-spark-advance-main.png
89irocz355
Dec 12, 2007 03:25 AM
AntiVTEC
Sep 5, 2003 09:37 PM
JAKEDPLAYA
Apr 18, 2003 11:15 AM
Paul_Hughes_87 T/A
Jun 28, 2002 06:23 PM
