305 tpi won’t run
Old Dec 15, 2017 | 11:39 PM
edman87k5's Avatar
Car: depends on the weather
Engine: several
Transmission: all manual
Axle/Gears: lots
305 tpi won’t run
What am I missing?
My 88 has sat around for about 3 years only getting cranked a couple times a year. The last time it cranked, it took a while to get it to run. I chalked it up to old gas and weak battery on a low amp charger
A month ago I was ready to bring it into the shop to start the interior refurb and could not get it to start at all. Fuel pump was shot. Changed fuel pump and cleaned tank. Fresh gas, filter etc.
still will not start.
I have correct fuel pressure- verified with gauge on rail.
Getting fire- verified.
Injectors are pulsing- checked with noid light.
It just turns over but will not start. No spit, cough, nothing. Just spinning over.
What am I missing?
Old Dec 16, 2017 | 07:39 AM
vinny R's Avatar
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
Re: 305 tpi won’t run
Originally Posted by edman87k5
What am I missing?
What am I missing?
I was watching an episode of Garage Squad and they were getting a GMC Typhoon running. After they fixed everything, they could not get it to fire. Even replaced the injectors. Turns out, they did not flush the fuel lines and fuel rail. There was crud in the lines from the car sitting, the new pump just pumped all that crude into the injectors and clogged every one.
Old Dec 16, 2017 | 08:14 AM
edman87k5's Avatar
Engine: several
Axle/Gears: lots
That was a thought and may be my next course of action. Have only had a few minutes at a time lately to mess with it.
Old Dec 16, 2017 | 10:20 AM
GeneralDisorder's Avatar
Likely bad injectors. All mine were bad after sitting 11 years.
GD
Old Dec 16, 2017 | 10:24 AM
edman87k5's Avatar
Engine: several
Axle/Gears: lots
It was last running less than a year ago.
Old Dec 16, 2017 | 10:25 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Fuel can start to degrade after a few months
If you have spark and fuel pressure..... there's not much else besides injectors that would stop it from at least trying to fire.
GD
Old Dec 16, 2017 | 12:07 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Spray some fuel or starting fluid into the TB (hold open when doing this). Then see if it fires for a short period of time (w/the TB closed). If so then there is a fuel delivery issue.
RBob.
Old Dec 16, 2017 | 02:58 PM
Caveman305's Avatar
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
can almost guarantee you have clogged injectors
i had to replace the pump on my Iroc, once that was done i had plenty of pressure at the Rail but the car wouldnt fire, i could get it to fire up on starting fluid and feather the throttle to keep it running but as soon as i let off it would die.
i ran almost a tank of gas with fuel system cleaner through while feathering the throttle now it fires up like normal and will run without me touching the throttle. plan for me is to replace the injectors when i get to that point in the project.
Old Dec 17, 2017 | 09:24 PM
edman87k5's Avatar
Engine: several
Axle/Gears: lots
It will crank and runnonstarting fluid but nothing without it.
Going to put in new injectors. New for and adding a rail gauge while I am in there. Will probably do tune up while I am in it.
While I had it still on the lift, I did replace the muffler. The muffler and tail pipes I removed had about 1/8” of buildup that looks like baked oil? Car ran fine and did not smoke. Guess I will figure that out after I get it running.
That ls swap is looking better and better every day!
Damn snowball effect.
Old Jan 20, 2018 | 12:38 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
II would completely drain the gas tank and put in all new fresh gas, and add some TCW3 2-cycle oil to the fuel..
91tpiwrangler
Apr 22, 2018 06:57 PM
birdman_29
Nov 7, 2010 10:46 PM
G-man
Aug 24, 2001 07:53 PM
