I want to run my own switch to run to run the fans, does anyone know how this is done
Old May 30, 2001 | 10:31 AM
JucinGTA's Avatar
I Read it somewhere, that you can just take the wire that is hooked up to your block and run that to a switch, and then run a power, and when you turn it on they both go on!! is this true? ? Will u loose your tempature gauge or do you just tap into the wire and leave it hooked up?
On my other bird, I maunualy ran a ground and a power to each fan, I dont want to do that again!!?
[This message has been edited by JucinGTA (edited May 30, 2001).]
Old May 30, 2001 | 03:08 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Look in the tech article section. There's a great post on how to do it. That ought to help you out.
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
86IROC112
Aug 17, 2015 02:00 PM
Bull86
Aug 10, 2015 05:43 PM
